Re: O/T Model A Axle
Wardner
11-30-2006 18:54:40
I looked again at the picture and I don't know what you have. That's a front hub and what looks to be a tie rod. However, the axle appears to be tubular vs I-Beam and would indicate a rear axle. You can't mix the two together. Anyway, you don't need the puller. Pry off the dust cap, extract the cotter pin, remove the large nut, and the drum and hub will come off if the brake linings are not "welded" to the drum. They probably aren't.
