Fuel for my x3
Farmall H Newbi
11-30-2006 23:35:27
I have a 1943 Farmall H x3. Can I burn gasoline all the time? Does it go in the tank closest to the driver?
Thank you for your help.
Marty Johns
12-02-2006 18:31:07
 Re: Fuel for my x3 in reply to Farmall H Newbie, 11-30-2006 23:35:27
From my experernce! I have tried both, low octane & hi the Hi will give better economy!!!!! !! I can use 2 gal. high oct. or 4 gal. reg. to mow a 2 acre feild!
Roger Mills
12-01-2006 09:11:49
Put gas in both tanks so you can get back to the barn.
Steven@AZ
12-01-2006 06:03:13
Run it on regular 87 octane gasoline. Chances are at some time in the last 63 years that the engine has been rebuilt with the higher compression pistons anyway. Either way, gas is just fine.
Rustyfarmall
12-01-2006 05:05:58
It's a pretty safe bet that the tractor has already been running on straight gasoline for about the last 30 to 40 years.
Nat 2
12-01-2006 04:55:55
87 octane gasoline is fine, in the big tank. You wouldn't be able to run very long on the little tank.
