Super C power--again
Chris from Wa
12-02-2006 10:36:46
I am interested in more power from my Super C. I had a source for high-altitude firecrater pistons but that disappeared. Does anybody know of a source for those? Does anybody have opinions on aftermarket pistons: Tru Power, Tisco, etc? I'm not interested in tractor pulling and didn't find much on that forum. I just need enough power to get a finish mower up some steep hills around my place.
gene bender
12-05-2006 12:00:31
 Re: Super C power--again in reply to Chris from Wa, 12-02-2006 10:36:46
Also check the part# as it will tell you if you can go to 3 1/4 bore or have to stay with 3 1/8 as the 3 1/4 will give you 135cuin and by running around 1750rpm you will have 26 or so HP.
Shaggy
12-03-2006 09:51:10
There is a Super C sleeve and piston kit on Ebay the number is 110062124592. Check it out it might be what you are looking for.
Chris from Wa
12-03-2006 13:19:32
 Re: Super C power--again in reply to Shaggy, 12-03-2006 09:51:10
Thanks Shaggy. I was looking at that kit. Is anyone familiar with Tru Power?
Shaggy
12-03-2006 07:20:03
Good morning!
You need to measure the bottom of the block where the sleeve stick thru to make sure what sleeve kit you need. The C-113 block measure 3 5/16th and the C-123 are 3 7/16th. I would think a C block would be 3 7/16th but that is just me thinking again.
Shaggy
gene bender
12-03-2006 04:15:03
Check the part # on your block as you dont have the right block you cannot use the 3 1/4 hi dome rebuilt kit. Get the serial number that is on the block under the #1 spark plug and then with the part# on the block you will be able to get the correct stuff for you power increase.
Chris from Wa
12-03-2006 13:00:43
 Re: Super C power--again in reply to gene bender, 12-03-2006 04:15:03
Thanks gene. I have checked the serial # and I do have the right block.
El Toro
12-03-2006 04:02:22
You can install an overbore kit in the Super C.
that increases the bore from 3.125" to 3.250" and
the cid from 123 to 133cid. There's no machining required to use this overbore kit. They have stepped head pistons too. Hal
Shaggy
12-02-2006 16:52:59
The kit I have in my B is a Tisco kit and the part number is TK-EOK 1154B. They sell the same kit on this site for about the same money I got mine and the compression won't be to bad with a stock head off a B.
Shaggy
El Toro
12-02-2006 13:40:04
NAPA auto stores sell Clevite sleeve kits. Not sure if they have the pistons you need. You can try this web site too for Clevite. Hal
www.heavydutyenginekits.com/CeekHD03.php
Chris from Wa
12-02-2006 15:20:32
 Re: Super C power--again in reply to El Toro, 12-02-2006 13:40:04
Thanks Hal
El Toro
12-03-2006 12:32:31
 Re: Super C power--again in reply to Chris from Wa, 12-02-2006 15:20:32
You can contact aicatalog.com for an overhaul kit
and it will include your bearings. Need to have the shaft measured so you know which bearings to order. I think the gasket set is included too for $378.00. Hal
