f20 engine kit
Bill Geer
12-02-2006 13:41:49
I'am looking to rebuild a f20 engine.
Wher do I find a kit and what will it cast?
El Toro
12-03-2006 17:56:41
 Re: f20 engine kit in reply to Bill Geer, 12-02-2006 13:41:49
He's the last name on this posting on page 2. Take a look at all of the responses to your posting. Hal
El Toro
12-03-2006 12:13:05
I would buy a new set from Justin. Hal
PS: Your local auto machine shop may be able to
locate new bearings. You should have the crankshaft measured for wear to see if it needs to be ground undersize or just needs polishing.
tractorust
12-03-2006 09:16:43
New sleeves are still available from a place in California called L.A. sleeves. I bought a set from them last winter and they are very nice. I don't recall what the price was on them. They have a site on the internet.
As for other parts Rice equipt (as stated earlier) has most of what you will need. There is also a site by the name of "The Fordson House" they also carry some of the same parts as Rice Equiptment.
We recently rebuilt a 1936 year model we put in new sleeves and reused the old pistons with new rings. It has been running fine for about a year with no problems. The F-20 engins is for the most part a simple set up to work on. The best advice I can tell you is to make a list of what you know you will need and start getting prices.
Spend your money on the engine, carb, and mag. Everything else can come later.
If you need any more help feel free to email me.
tractorust@yahoo.com
F-Dean
12-03-2006 08:15:57
If the sleeves are not too badly rusted, have the head rebuilt (This may require some new valves) at a machine shop; New rings; and set the rods using pasti-gaue should surfice. New Rings, valves guides and valves are available from Rice Equiptment (814) 226-9200.
the
12-02-2006 16:47:55
There is a set of used pistons, sleeves and rods on E-bay right now, not mine.
Yugrotcart
12-02-2006 13:53:51
Bill ,
Get a hold of the "F20 King", I'm sure Hoeard can help you out.
Paul
SproutW
12-02-2006 15:06:18
 Re: f20 engine kit in reply to Yugrotcart, 12-02-2006 13:53:51
A rebuild kit (pistons, sleeves and rings) has not been available for many years. Most people reuse their pistons if useable and have new sleeves made or fit a dry sleeve within your old sleeve. Nebraska may have a good set of pistons and sleeves for you at a much cheaper cost. Either way the F-20 engine cost some money to rebuild. I wish someone would start making rebuild kits for them again.
justin w
12-02-2006 17:55:11
 Re: f20 engine kit in reply to SproutW, 12-02-2006 15:06:18
I have NOS sets of Pistons and sleeves available for the F20 in STD altitude, 5000' Alt, and 8000' alt.
