rear main seal replacement on IH W4
n8terry
12-02-2006 14:56:00
Is it possible to replace the rear main seal while the engine is in the tractor?
I would appreciate any advice on how to do this if it is possible.
John M
12-03-2006 10:14:24
 Re: rear main seal replacement on IH W4 in reply to n8terry, 12-02-2006 14:56:00
Its much easier and faster to pull the engine
55 50
12-02-2006 16:44:40
Not sure on a W-4, but on a WD-9 we had to lift the motor and set it crosswise on the main frame (oil pan was off) to get to the rear main. Of course we found out later that the rear main bearing was worn and that was why the original oil seal was leaking. You may have a bad rear main bearing if the seal is leaking.
