2400a water pulley removal?
rret
12-03-2006 05:32:44
i have a 1977(?) IH 2400a (similar to a 454). i need to remove the pulley from the water pump - how is that done? does it screw on? the pump is on my bench with the pulley attached somehow - i can"t figure out how to get it off
rret
12-05-2006 10:32:56
 Re: 2400a water pulley removal? in reply to rret, 12-03-2006 05:32:44
guys- thanks for your help. turns out that the pulley just comes off - mine was rusted to the impeller shaft so it wasn't obvious. a little PB Blaster freed things up.
so procedure is:
1) remove 4 bolts holding fan on.
2) remove fan.
3) remove pulley.
Fromjb2
12-03-2006 08:49:35
Hi, unless you have a proper press for removing the pulley hub and bearing, you will crack the water pump casting. My brother has been there done that on his 454. In Canada CIH stocks a remanufactured water pump for about $80.00 CND with your old casting. If you break casting replacement pump is more than double the exchange price.
Should be common part for 454,574,674,484,584,684.
JB2
El Toro
12-03-2006 07:49:52
The pulley may be pressed on. Send an email to
cslothower@hoober.com and they have their service manuals and will look up this info for you. You can call them too at 1-800-732-0017 and ask for farm tractor service. Hal
