Calcium chloride in tires
Charles McNelly
12-03-2006 08:18:35
I bought a W-6 from Colorado and the tires are filled with Calcium chloride. I feel it does more harm then good. How do I dispose of this stuff? Can I just spill it on the ground?
Thanks,
Charles
klf
12-03-2006 18:21:26
 Re: Calcium chloride in tires in reply to Charles McNelly III, 12-03-2006 08:18:35
As long as it isn't leaking, don't worry about it. Unless you take the tube out, you will not get it all out.
John65
12-03-2006 11:30:00
There is a new product out that is farm and animal friendly it's called Rim Guard.
www.rimguard.biz/
hayfarmer
12-03-2006 11:07:38
You might contact a local tire store and see if they would take it off your hands. They do reuse it.
El Toro
12-03-2006 10:44:19
Our local Case/IH dealer won't touch a tractor tire with calcium. It's hard to dipose of here in MD. They recommend using used ethylene glycol
antifreeze since it can be recycled and isn't so corrosive as calcium chloride. Hal
Jim Allen
12-03-2006 09:26:26
I used what I drained on an area of my gravel road the was connstantly growing weeds. Kept 'em away for about two years! I got rid of mine after the tire delveloped a small leak and started corroding the rim, The stuff really eats steel pretty fast, too! I put iron wheel weights on, which I can remove or mount as needed.
CNKS
12-03-2006 09:01:54
I agree with Randy. I wouldn't want to dump 100 gallons of the stuff. Whether it is an enviornmental concern, I don't know, but you will sterilize the immediate area for a while. If you happen to have a tractor mounted sprayer, and an area to spray it, spray it out -- or else spray it on a roadway as Randy suggests. Or call the tire company, and they will take the stuff, for a fee.
randy hall
12-03-2006 08:41:45
if you have a stone driveway that is a good place to drain it. when there were a lot of stone roads around the county used to spray it on the stones to hold the dust down. now the state highway dept. sprays the highways with it before it snows. but i'm sure some 'greenpeace' person would tell you to take it to a hazardous landfill.
Charles McNelly III
12-03-2006 15:56:15
 Re: Calcium chloride in tires in reply to randy hall, 12-03-2006 08:41:45
Thanks Guys,
Charles
