340 U Hydraulic Oil Change Update
suumoe
12-03-2006 13:51:20
Replaced fluid and filter along with cleaning screen. Power steering was better but would still come and go at certain times. It may just be me,but it seems the steering works better at lower engine rpm. I would think it would be the other way around,the higher the pump rpm the greater the steering response. I am wondering since this is power assist instead of power steering maybe there is some sort of proportional valve in the power unit regulating flow during different steering situations. I have ordered a manual for it but hasn't arrived yet.What do you think tractor gurus? does this sound possible?
fred dee
12-03-2006 14:43:14
 Re: 340 U Hydraulic Oil Change Update in reply to suumoe, 12-03-2006 13:51:20
assuming that your tractor has the transmission pump rather than the front crankshaft to operate the loader, I once found that the short pipe that connects the pump to the filter was pulled to far into the filter, and only butted up to the pump thereby sucking air. My fix was to remove the pump and push the tube (short Pipe) firmly (with good Oring) into pump and carefully reinstall pump, and was good to go. If you need picture email me
suumoe
12-03-2006 17:44:44
 Re: 340 U Hydraulic Oil Change Update in reply to fred dee, 12-03-2006 14:43:14
Could be a possibility. It does sound sometimes like it is cavatating.If you could email the pictures that would be great. My adress is:suumoe@yahoo.com Thanks
Janicholson
12-03-2006 14:07:53
Just open brainstorming here, but interesting.
If the diverter (priority) valve which controls the path of the hyd. oil to the steering/hitch/remotes, is in need of repair/reseal or replacement the symptoms might duplicate those you find. Additional flow volume may make the valve more sensitive to jerky motion. If all other hydraulic processes are powerful and smooth, I would suspect tha valve. If other problems with hyd. are present, I would suspect the pump. JimN
suumoe
12-03-2006 14:15:11
 Re: 340 U Hydraulic Oil Change Update in reply to Janicholson, 12-03-2006 14:07:53
This tractor does not have PTO or 3point hitch, so all the hydraulic pressure goes to the steering unit.
Janicholson
12-03-2006 14:57:21
 Re: 340 U Hydraulic Oil Change Update in reply to suumoe, 12-03-2006 14:15:11
I believe the complete Hyd system will be in place to allow the addition of remotes. This will (I believe) include a priority valve. Thus that is where I would look first.
If it is not equipped with a pump at the distributor, and has a seperate powersteering pump only, everything I have said is irrelevant. JimN
suumoe
12-03-2006 17:38:09
 Re: 340 U Hydraulic Oil Change Update in reply to Janicholson, 12-03-2006 14:57:21
Jim,my pump is located inside the transmission case.
Janicholson
12-04-2006 06:27:22
 Re: 340 U Hydraulic Oil Change Update in reply to suumoe, 12-03-2006 17:38:09
I believe you are going to need a service manual, or parts break down. There is a online parts breakdown, (search archives for on line parts diagrams). It will most likely have a diverter valve. JimN
suumoe
12-04-2006 08:18:50
 Re: 340 U Hydraulic Oil Change Update in reply to Janicholson, 12-04-2006 06:27:22
I will check it out. Thanks Jim
