Need help on Little Genius 3 Bottom
CenTex Farmall
12-04-2006 06:37:02
I have Genius 3 bottom that I am refurbishing, used to have steel wheels but was modified ages ago to use tires. The tire for the land wheel is completely shot. If you own one on steel, could you check the diameter of the wheel and let me know what it is. Then I can find a tire that's pretty close.
Thanks
Dave S.
12-04-2006 16:06:34
 Re: Need help on Little Genius 3 Bottom in reply to CenTex Farmall, 12-04-2006 06:37:02
I have a 2-14" Little Genius on steel, the left wheel(lift wheel) is 29 1/2" dia., right wheel (furrow wheel) is 23 1/2" dia., tail wheel is 18 1/2" dia.,(at the widest point not the tapered side).
Dave
CenTex Farmall
12-04-2006 18:29:07
 Re: Need help on Little Genius 3 Bottom in reply to Dave S., 12-04-2006 16:06:34
Thanks!
That gives me a good idea of what to look for in a tire, should make adjusting it easier.
Paul G. in Mn
12-04-2006 13:49:37
I picked up a 2-16 little genues and it has odd wheels on it. The fronts are 16" with a 5 spoke cast center. They clamp on just like a tractor front tire. I used a tire and rim from my M and clamped it on. The clamps are the same as my 39 F-20.
Rustyfarmall
12-04-2006 14:06:11
 Re: Need help on Little Genius 3 Bottom in reply to Paul G. in Mn, 12-04-2006 13:49:37
Got any pictures? I've never seen that type of wheel on a plow.
Paul G. in Mn
12-04-2006 16:12:01
 Re: Need help on Little Genius 3 Bottom in reply to Rustyfarmall, 12-04-2006 14:06:11
I dont right now, can take some next trip to the farm probly be christmas. bad part is they cut one of the center and bolted a truck wheel on it
John A.
12-04-2006 09:36:14
CenTex, You are new here arn't you. Where are you located,just out of curiosity. If you arn not new I appoligise for not seeing you here before.
I am 27 mi S. of Lampasas
Later,
John A.
CenTex Farmall
12-04-2006 18:45:11
 Re: Need help on Little Genius 3 Bottom in reply to John A., 12-04-2006 09:36:14
I'm a little ways northeast of Waco. I've been looking here for a couple of years but mostly just lurking. A lot of times I can find the answer I need by doing a search of the forum.
John A.
12-04-2006 19:44:15
 Re: Need help on Little Genius 3 Bottom in reply to CenTex Farmall, 12-04-2006 18:45:11
Cen-Tex, Glad to meet You. Hollar whenever you want, If I can be of assistannce. if it looks like it will get long and drawn out we can swap phone # if you like then we can chew on it a while. Later,
John A.
Rustyfarmall
12-04-2006 07:00:21
I've got a 2 bottom on steel, but I can't get out to it right now. The 2 bottom little genius that I use is also on the cut-down steel wheels. The tires were totally rotted away when I got it, so I replaced them with a pair of used tractor fronts. Land wheel and furrow wheel both with the same size tire. Not correct, but it works very well. Another 3 bottom plow that I have is equipped with rubber tires, and uses a 7.00 or 7.50 x 15 pick-up truck tire on the land side, and a smaller, car sized, 15 inch tire on the furrow side.
CenTex Farmall
12-04-2006 07:26:00
 Re: Need help on Little Genius 3 Bottom in reply to Rustyfarmall, 12-04-2006 07:00:21
Thanks
The furrow tire on this one is unusual. It has no tread and slopes steeply from one side to the other. It"s heavily weather checked but holds air. I"m going to try it and see how long it lasts! Couldn"t find a 4.00 X 12 for the back around here, but did get close with a 4.80 X 12.
Also Binder Books has two manuals for Little Genius #8, one is from 1929 and has parts list the other from 1951 and says something about a parts list for the H and M. Not sure which one to go with, Maybe somebody here has seen them and can shed light on it.
Rustyfarmall
12-04-2006 07:39:23
 Re: Need help on Little Genius 3 Bottom in reply to CenTex Farmall, 12-04-2006 07:26:00
The 4.00x12 tapered tire is actually what most of us call the "tail wheel". I think the tapered tire for the tail wheel is available now but I don't know who has it. Maybe Miller tire? The little genius that I use still has the original steel tail wheel. I can't shed much light on the manuals in question, but 1929 seems a bit early for a little genius. I might be wrong.
CenTex Farmall
12-04-2006 07:48:52
 Re: Need help on Little Genius 3 Bottom in reply to Rustyfarmall, 12-04-2006 07:39:23
I haven't checked with Miller on that one. Shipping shouldn't be too bad on one that small. I agree that '29 seems kinda early.
