Letter Series Light Bar
Dennis Gauge
12-04-2006 08:43:40
What is the correct way to mount the light bar on a letter series? I"ve seen them both ways now and I"m confused:
1. Behind the steering post with the smooth side of the diamond-shaped plate facing forward?
2. In front of the steering post with the smooth side of the plate facing the driver?
Dad"s old Super M has it mounted in back.
Dad"s new Super H has it mounted in front.
My Super H has it mounted in back.
The November picture on my Farmall 2007 calendar has an H with it mounted in front.
I would think for the lightbar toolbox to work, it would have to be mounted in back.
LA in Wi.
12-05-2006 07:42:15
 2007 Farmall calendar in reply to Dennis Gauge, 12-04-2006 08:43:40
Dennis Gauge, where did you find that 2007 Farmall calendar?
Ken B
12-04-2006 10:16:09
 Re: Letter Series Light Bar in reply to Dennis Gauge, 12-04-2006 08:43:40
The light bar goes on the back side of the post. There is a alinement bump that goes in the cutout on the light bar. Be careful with the U bolts they are not muffler clamps they are an odd size . been there Ha
ejr-IA.
12-04-2006 09:20:50
The old photos I've looked at shows the bar on the back.
BOBM25
12-04-2006 08:48:42
I agree with it on back. Isn't there also a small pin on the post that aligns with a slot on the light bar? I think the pin is supposed to be the rivet that holds the top cast part of the post (where the steering shaft goes thru) to the pipe part of the post. Alot of these I've seen have been ground off and replaced with a bolt.
