MD serial number on eng
petenev
12-04-2006 09:26:28
hi can anyone tell me where to find serial number on diesel eng. i have 3 of these and have looked many times on each and no luck, been told left side top of eng. thanks pete
Haas
12-04-2006 18:30:02
 Re: MD serial number on eng in reply to petenev, 12-04-2006 09:26:28
The engine serial number is located on the left side of the crankcase (engine block). It's just in front of the diesel speedcontrol/gas to diesel switchover unit that is mounted on the left side of the block. Also just over the top of the oil fill port for the injection pump. There is a flat raised place on the block. The serial number is stamped on that.
IHC-Farmall
12-04-2006 16:21:47
It might be on the left or right side not sure, but where the head goes onto the block there should be 2 little lips on each side of the head that have the serial number on it.
MI Mark
12-04-2006 16:21:18
there is no tag it will be a stamped number in the cast on a machined flat surface not sure just where never looked on ours. mi mark
