buckets
redboy656
12-05-2006 11:27:40
hay all, anyone know where I might aquire a set of loader buckets for an International 656, 1972 model? They don't have to be in very good condition. I live in Western Massachusetts.
Hugh MacKay
12-06-2006 02:47:37
 Re: buckets in reply to redboy656, 12-05-2006 11:27:40
redboy: It would help to know the model number of the loader. There were probably 1/2 dozen loaders installed on 656s over the years. Tractor model tells very little.
If the loader is an IH 2000 or newer, most any modern day loader bucket could be made to fit with a bit of fabrication. Most all loaders using two bucket cylinders out front on loader arms, have the same basic configuration as it applies to the bucket. You might even find a fabricator to make you up a universal quick attach plate for the loader, then sky is the limit on buckets. Bear in mind it has to be an IH 2000 or newer loader.
