Carb. Adjustments
Texas300U
12-05-2006 15:54:16
I have a 300 utility and have brought it back from the dead and now am having problems with the plugs fouling.I have adjusted the Carb.warm and hot. no change. Have I over looked something.
Thank you
rp-40-9N
12-05-2006 19:31:43
 Re: Carb. Adjustments in reply to Texas300U, 12-05-2006 15:54:16
TEXAS, I HAD SAME WITH A CUB THAT I BROUGHT BACK FROM THE DEAD, REPLACED NEW CHAMPION PLUGS WITH AUTO LITE PLUGS, PUT ONE HALF BOTTLE OF MMO IN FUEL TANK, THE REST IN CRANK CASE. EVERY DAY FOR NEXT FIVE DAYS IT GOT BETTER AND BETTER, THEN I COULD SET THE CARB AND TIMMING AND LET ER RIP. rp
old
12-05-2006 16:41:15
What type of fouling does it have sotty and black or oily and black?? If its sotty then first off check the air cleaner and see if its clogged up. Also check that the choke isn't stuck closed. Then adjust the main jet by turning it all the way in and then back it out about 3 full turns. It may need to be adjust out more but the 3 turns is a good place to start. You should be able to turn it in to a point that the engine dies then turn it out about 1 turn from there and see what happens
