M 9 Speed
Martin Benton
12-05-2006 23:23:56
Does anyone have a diagram or picture of some kind of a 9 speed? I have one on my 1950 M and the pull control is rusted or something is jambed up. I can't move the thing from low to high. I'm not sure how to get at the thing. Thanks for the help.
randy hall
12-06-2006 20:23:25
 Re: M 9 Speed in reply to Martin Benton, 12-05-2006 23:23:56
i hope for your pocketbook that it is just jambed up. i have parted out two m's with nine speeds that have been welded up and screwed up.
kfox
12-06-2006 02:42:45
I have a M&W 9 speed on a H. Does your tractor use a shifter that looks like a heavy duty choke cable? If it has that kind of shifter, you may be able to drain the transmission and remove the belt pulley gearbox to check the other end of the cable. It hooks on to a shifter fork in the bottom of the transmission near the front. If I knnew how to post photos on this board, I could post a few. ken
