404 IH
E Harmon
12-06-2006 10:57:54
I am having difficulty diagnosising a "fire" problem. I am not getting spark to the coil. The alternator light started flashing about 4 weeks ago, and then I was running the tractor and it just stopped dead in it's tracks and would not restart. There was a wire broke off of the converter (I am not sure what it is called, it is located just under the gas tank). Anyway, the coil is good (I had it tested)and we are not getting electricity to the coil.
Any help would be appreciated.
Thanks.
IH2444
12-06-2006 13:18:34
 Re: 404 IH in reply to E Harmon, 12-06-2006 10:57:54
The voltage regulator ? Left side under the edge of the gas tank ?
It sounds as if your battery is dead, any power in there ? Is the ignition switch ok ? You will just have to trace it down and find where you are losing voltage to the coil.
