Flush it out
Tom Windsor
12-06-2006 12:12:17
I thought I had flushed out all of the bad stuff in this restored H. I had never used the Hydraulic pump... so..never considered it. I drained it out today...bad stuff...very bad stuff...been in there 30 years I bet.
TW
JayWalt
12-06-2006 15:56:15
 Re: Flush it out in reply to Tom Windsor, 12-06-2006 12:12:17
No pics?
I'm sure you know to change the filter, and if the oil is that bad, you'd be best to clean the resevoir and flush out the lines and the pump.
neblinc
12-06-2006 12:55:28
I ended up pulling out the pump on my H when I first got it to fix all the seals. I could barely pour out the "oil" it was so bad. Still ended up taking off the cover, and gave it a good cleaning.
Randy
IowaFarmall
12-06-2006 13:47:50
 Re: Flush it out in reply to neblinc, 12-06-2006 12:55:28
What did you guys use to drop the pump out of the tractor? A jack? I need to replace the oil seal in mine and am not sure what would be the best way to get it onto the floor.
williamf
12-07-2006 02:02:28
 Re: Flush it out in reply to IowaFarmall, 12-06-2006 13:47:50
third party image
Being by myself, I did it with a wooden box and a couple of come-a-longs. A few pieces of board to help it balance on the flat surface. Slowly, carefully.
RustyFarmall
12-06-2006 14:08:10
A floor jack and a couple extra pair of hands. The belly pump is heavy, but it is also quite awkward. It does not like to sit on the pad of a floor jack, so one person to run the jack, and another pair or two of hands to balance the pump and make sure it does not fall off the jack.
