Something unexpected every day!
Tom Windsor
12-06-2006 15:10:59
third party image
Yesterday, I was so excited to have found all the appropriate supply lines back in the corner of my shop to plumb in the 3 point hitch. 2 supply lines to the cylinders...just the right length and a braded line to run up front. Happy day...but...no...not to be...end fittings at the T turned out to be non standard Japaneese or something...maybe metric...maybe not...the result was to clip them off and put new ones that matched the T. Oh well...something new every day.
mdntspec
12-07-2006 09:15:06
 Re: Something unexpected every day! in reply to Tom Windsor, 12-06-2006 15:10:59
maybe you have a tee for fuel lines - fuel lines use a 45 degree flare with fine threads... hydraulic lines use a 37 degree flare with a coarse thread... just so you can't mix the two up!! Different applications, different pressure ratings!!!
Bus Driver
12-07-2006 04:46:02
The tee looks to be brass. Brass is not good for hydraulics. The pressure peaks flex and weaken the brass. The higher the pressure, the quicker the failure. Those are available in steel.
Tom Windsor
12-07-2006 14:11:17
 Re: Something unexpected every day! in reply to Bus Driver, 12-07-2006 04:46:02
Good point...I will shop around and get one.
Thanks. Wasn'thinking.
TW
Tom Windsor
12-07-2006 14:11:11
TW
Scott Griffith
12-06-2006 17:53:33
Yep,
Everyday I go to start my Farmall A it is always something...But once it"s starts it never quits unless I run out of gas.
Scott
James Williams
12-06-2006 16:35:52
Tom,I worked all day putting gas lines on one of my F12's,and nothing worked right
JayWalt
12-06-2006 15:36:33
I know the feeling =)
