H Recharge Dumb Question
b2187101
12-07-2006 07:51:27
OK I'm really going to show my ignorance with this question but I've got to ask... I have a 51 H that runs and looks really good (newer not restored paint, bad tires, starts in freezing weather with a 6 volt). When I start my H what exactly is recharging the battery, if at all? Should I periodically run it for a time this winter to keep the battery charged? I know enough not to hook a charger to the battery like you would a car (positive goes on a bolt- negative goes behind the starter button right?) Waiting for my operators manual. Father in law is coming over this weekend to help drain and refill radiator and I don't want to look too dumb. Thanks for yor help.
John T
12-07-2006 08:33:07
 Re: H Recharge Dumb Question in reply to b2187101, 12-07-2006 07:51:27
b21
"When I start my H what exactly is recharging the battery, if at all?"
The charging system is which is composed of the generator and associated Voltage Regulator or Cutout Relay if it allll works.
"Should I periodically run it for a time this winter to keep the battery charged?"
Probably no need to do so, if youre concerend use one of those smart trickle chargers or battery tenders now n then to keep it charged cuz its better then setting ther in an uncharged state. You could take it out n store in a warm basement etc.
"I know enough not to hook a charger to the battery like you would a car (positive goes on a bolt- negative goes behind the starter button right?)"
Pos/red of charger goes to + of battery and Neg/black of charger goes to - post of battery REGARDLESS if youre at pos or neg ground cuz even though if it were originally Positive Ground, it may have got changed
John T
Bob M
12-07-2006 08:15:49
Presuming your H electrics are stock and working, the generator (hidden up under the hood on the right front side of the engine) recharges the battery when the engine runs.
Understanding the ammeter will tell you all you pretty much all need to know about battery/generator operation:
The ammeter keeps track of current flow into/out of the battery. Ammeter hand deflected to the right of 0 means the battery is being charged, and to the left of 0 means discharge. And the farther the needle moves away from 0, the higher the rate of charge or discharge.
If the ammeter and generator are working properly, with the engine stopped and everything shut off the ammeter will be centered. (Meaning no current flowing to/from the battery.) With the ignition switch "on" and the engine stopped the ammeter will indicate several amps of discharge. Likewise with the engine at slow idle the ammeter will indicate several amps of discharge. This is because the generator does not provide any current at idle speed. The ignition is drawing off the battery to keep the engine running
However with the engine running at speed the ammeter should indicate half scale or more on the charge side, showing the generator is charging the battery.
I personally wouldn't bother running the engine occasionally to charge the battery during the winter. Better simply to leave it alone (that's what I do with mine...). Or if you prefer remove the battery and stick it on a charger overnight once every couple of months.
Bob
12-07-2006 07:59:10
Leaving 6-Volt trickle charger, or, even better, a "float charger" hooked up all the time in freezing weather is a GREAT idea, and also will extend battery life by YEARS.
Simply match the polarity of the charger's leads with the markings next to the battery posts.
daves40 acre
12-07-2006 07:58:13
The generator recharges the battery thats if it still works, other than that you shouldn't have to charge battery during winter if sitting unused, that is if you have a good battery too. Look to the left of this page under articles there should be an article on Farmall H that will help some for education on your tractor.
