Super A, What year is it?
JPM in WA
12-07-2006 10:20:34
I have a SA with no ID plate on the Transmission. Is there any other way to ID it correctly?
JPM in WA
12-07-2006 17:22:22
 Re: Super A, What year is it? in reply to JPM in WA, 12-07-2006 10:20:34
I located the plate on the transmission housing and the engine. They both end with a "T". So according to the info posted earlier I will assume that it is a 1950. Thanks for all the input folks.
Thanks for the offer Mark, but I live in Western WA.
City-Boy McCoy
12-07-2006 17:32:46
 Re: Super A, What year is it? in reply to JPM in WA, 12-07-2006 17:22:22
There is not going to be a T on the plate. You must be referring to the casting date codes.
JPM in WA
12-07-2006 20:11:37
 Re: Super A, What year is it? in reply to City-Boy McCoy, 12-07-2006 17:32:46
Yes, I am. They were 4-3-T on the Tran. housing and 5-6-T on the engine block. Is that correct that this means it is a 1950 model?
Hugh MacKay
12-07-2006 21:49:17
 Re: Super A, What year is it? in reply to JPM in WA, 12-07-2006 20:11:37
JPM: Sounds right to me.
banjo
12-07-2006 16:10:36
I stand corrected, i assumed you were talking about the seat bracket mounted to the transmission/axle tube. sorry
Mark in WA
12-07-2006 12:47:06
JPM, Where are you located. I just finished a Super A resto this past summer and would be glad to assist if you are in eastern WA.
Keith-OR
12-07-2006 13:53:22
 Hey Mark in reply to Mark in WA, 12-07-2006 12:47:06
Where you located in E WA. I am about 30 miles S of Tri-cities on OR side of the Mighty Columbia.
Keith & Shawn
Hugh MacKay
12-07-2006 12:26:03
JPM: If the serial number is not on left seat support, I'd tend to follow the casting codes as Mike has suggested. The problem with SA engine serial numbers is that while they remained quite close to tractor serial numbers from 48 until 51, that did not continue. At tractor serial number 310000 a new block was introduced and from that serial number onward a spread between the two developed. By the end of Super A production, engine serial numbers were running 2000 higher than tractor serial numbers. I've checked a couple dozen tractors and the spread grew by about 600 per year consistantly.
City-Boy McCoy
12-07-2006 10:39:21
JPM: First of all, the ID plate on a Super A is not on the transmission housing; it is under the seat on the left side seat frame.
Secondly, if the plate is missing from there, you can look at various casting dates on the main components of your tractor. Example: 4-2-Y is April 2, 1948. S = 1949 and so forth, there is no V, U and W are both 1951, X is 1952, Y is 1953 and Z is 1954 (final year for the Super A).
mike
banjo
12-07-2006 10:37:12
should be a number just above the dist or mag on the engine block. just below the # 1 plug on a little flat area . it will get you close as these numbers and the id tag may of been off by 100 or so depending on the year.
J.W. simmons
12-11-2006 17:41:26
 Re: Super A, What year is it? in reply to banjo, 12-07-2006 10:37:12
I have a super a that still has serial. it is a 1951 and I have cleaned the block by the no. 1 plug there is no no. there. I wonder if this is a replaced block or if this tractor was made on a monday or friday afternoon. any idea why this is?
