Info on International T5 bulldozer
Ken showers
12-07-2006 12:03:20
Hi, need info for International T5 bulldozer on total weight of machine with blade,(and weight of blade alone), hydraulic operating pressure, approx amount of time to access steering clutches and is it possible to insert shim discs to tighten up clutches ?
Am hoping to buy this machine, which hasn't run for 20 years, and have to move it off their property somehow.
Thanks..... .....
Ken
td5doug
12-07-2006 16:56:56
 Re: Info on International T5 bulldozer in reply to Ken showers, 12-07-2006 12:03:20
Ken,Depending on what features the machine was equipped with,ie standard trans only, or with reverser or T/A, 3point or not etc & which piece of literature you look at, the bare machine weighs 5500 to 5900 lbs. there were 4 different model blades available. they weighed between 1200&1800lbs.
The hydraulic pressure spec is 1800-2000 psi
Time wise to disassemble the steering clutches, depends how miserable things are to come apart, in a perfect world an hour per side would get you pretty near done, but if its been sitting for 20 years you could probably spend a day per side fighting rusted & seized pieces & still not see the end.
I would just replace the fibre & steels as needed if you have gone to the trouble of tearing it appart. Fibre discs & the steel plates are still available. The brake band you can have relined.
