140 pressurized radiator cap
Farmall Larry's
12-08-2006 07:57:21
Working on putting my cooling system back together and am putting a new cap on the radiator. The current cap says 4 lbs. I have no idea if it is original. Should I stick with 4 lbs. or could I go up to 7 lbs? What is recommended? Thanks, George
Hugh MacKay
12-09-2006 05:06:59
 Re: 140 pressurized radiator cap in reply to Farmall Larry's , 12-08-2006 07:57:21
George: I can't find anything on my cap. Could be under paint. 140 cap looks like a very common cap with a added IH dome spot welded over it. I'll bet rating is on cap.
Hugh MacKay
12-08-2006 14:10:29
George: I just looked in a couple of books I have, came up empty. I'll be out in my shop in morning, will check 130 and 140. Caps will tell me.
