international 125B
Kieran
12-08-2006 13:33:55
hi there i have an international 125b crawler loader with a d239 engine and bosch EP/VA4 100H 1050 BR12-4 injection pump. will any other model pump work?
Kieran
12-13-2006 06:21:14
 Re: international 125B in reply to Kieran, 12-08-2006 13:33:55
hello everyone my 239 has a 3.875 inch bore and a 5.0625 inch stroke. rated speed 2100, high idle 2310, low idle 650-750rpm. firing order 1-3-4-2. tappet clearence(hot) inlet 0.010inch, exhaust 0.012 inch. will she run with a pump from a 684 ect..??
Fromjb2
12-09-2006 10:16:45
Hi Kieran, check out this web site for Bosch type VA injection pumps:>Link
All>Link the parts are listed on the CIH parts site for the Bosch VA 4/10H 1200 CR12-12 injection pump for 684 with D239.
I don't know the difference between the D239 used in 125B Crawler and the 684 ag tractor.
Good luck
JB2
Kieran
12-09-2006 13:09:26
 Re: international 125B in reply to Fromjb2, 12-09-2006 10:16:45
Thanks JB2 ill check that out and let ye know how i get on. Regards Kieran
Fromjb2
12-08-2006 18:14:06
Hi Kieran, the German build D239 was used in many agricultural tractors 574,674,684,685,695,4210.
The 574 thru 685 used a Bosch VE 4/10H 1200CR12/12 injection pump and the 695 and 4210 used a Bosch VE 4/11F 1200R277 injection pump.
The fuel and throttle control hookups for the different Bosch injection pumps are different.
Most common problem with the older Bosch pumps was the front seal on the drive shaft would wear out and let Diesel fuel leak into the crankcase oil. Seal is about $8.00 but have to remove pump to replace.
Hope this helps
JB2
Kieran
12-09-2006 06:25:29
 Re: international 125B in reply to Fromjb2, 12-08-2006 18:14:06
Hello JB2, my problem is that i lost 1 distribution valve while the pump was dismantled (dont ask!)and cannot get the part or a replacment pump anywhere.sorry for delay
