IH 2000 Loader-Need Advice
KDJ in IA
12-09-2006 05:13:45
Hey All,
My first posting to what seems to be a wonderful source of information.
We just got an old M, gas, in pretty good shape. It has a 2000 loader on it which has been painted and "looks" nice. We think it is not plumbed correctly due to the placement of the lines and actions of the loader.
Is there a source such as a manual reprint or something that can give us a schematic? Or if I take some pics would someone be willing to check it out?
It was so cold here that we just looked at it quick when we bought it. We also bought a wide front for the M and were going to put it on but now we are wondering if we can even do that with this loader on?
Thanks for any input!
Weldon K
12-09-2006 17:53:26
 Re: IH 2000 Loader-Need Advice in reply to KDJ in IA, 12-09-2006 05:13:45
KDJ, I agree with Nat2. I have manuals for both 2000 and 2001 loaders. The 2001 manual has instructions for mounting the loader on an M. It has schematic of the various pipe fittings plumbed into a system to operate loaders with single acting cylinders (power up -gravity down) that tractors, such as H and M with their primitive hydraulic systems, were equipped to operate. I do not know if it will help you, but I can e-mail to you some pages from the manual, if you want. The 2000 loader will fit on 856 tractor with the correct front mounting brackets and the correct axle mountings on the subframe. The front mounts for an 856 and the M are very different as are what is required to mount the subframe to the rear axle. The manuals show all the various front brackets and rear axle mounts for all tractors these loaders were intended to fit.
Send me an email if interested.
Weldon K
Nat 2
12-09-2006 15:32:25
KDJ,
The 2000 loader is a pretty big loader for an M. It's not even meant to go on an M. I've got a manual and it doesn't even go into installing one on an M due to the lack of high-capacity, two-way hydraulics that the loader really needs to work properly.
Speed is a function of GPMs, gallons per minute, and even if this M has a live pump, it's not going to set any land speed records moving the loader. It's going to be slow.
Sounds like the arms are plumbed for pressure-up and gravity down using the tractor's standard 1-way hydraulics. Do you pull the lift rod that goes to the belly of the tractor to raise and lower the loader?
The belly pump doesn't hold enough fluid to lift the loader all the way by itself. The hose and TEE that run under the belly are probably plumbed into the belly pump's drain port, and the "dead" side of the cylinders are supposed to be filled with oil to supplement the belly pump reservoir.
To get "power down" for the arms you will need to add a two-way valve into the system.
To make it go faster, you will need to get a different tractor.
You can add the wide front, no problem.
KDJ in IA
12-09-2006 16:31:32
 Re: IH 2000 Loader-Need Advice in reply to Nat 2, 12-09-2006 15:32:25
Hi Nat,
Wow, thanks! Excellent information. What you say makes sense.
re: operating the loader: There are 3 levers mounted on the right side of the steering wheel. Two are for the loader and one for the rear blade. One of the two operates the arms and the other operates the bucket. Okay, now going to explain how its hooked up. I do have a picture but need a close up of the right side for full viewing pleasure. lol
The hoses to these levers come from what we are assuming USED to be the much lower fill pipe. It has obviously been made taller and then it tees off to the three hoses, continues up where it has a fill cap, vented nonetheless. Actually, from this point it is too hard to explain so I will stop here.
The belly lever on the right side by your shin (I assume this is what you are talking about) turns a cylinder, on the right side, that appears as tho you can bolt on a pulley. This only operates when the clutch is released and the lever pushed in.
There are also two threaded ports on each side of the belly that are capped for a total of 4 capped ports. Have no clue what those are.
I am working on putting up a page with many pictures as one sure wont do the trick. We do have an 856D that we considered putting this loader on but it doesn't seem like it is wide enough for the 856. There are spacers on the M and then very deep mounts. I don't know if the loader had been cut out because it was originally on a larger tractor.
Thanks so much for your wonderful information and I will post when I get that page up.
gene bender
12-09-2006 06:46:50
I would be hard to believe that it is not installed correct as the former owner used it. Have you tried to raise and lower. Where do you live it appears in IA as im just south of IA CITY and could run over and take a look. I would lift and lower first. When you pull the lever back do it careful.
KDJ in IA
12-09-2006 07:10:59
 Re: IH 2000 Loader-Need Advice in reply to gene bender, 12-09-2006 06:46:50
Howdy Gene,
The loader works as it goes up and the bucket moves. Our contention that it is plumbed wrong is because of several things.
1. It is very slow going up and even though we topped off the hydralic fluid, it does not go up all the way. 2. It goes down by gravity only.
3. It has no down pressure when you get to the ground level.
4. The small return line that runs along side of the left piston has no hose attached to it and the one on the right is attached by a T to a line running UNDER the tractor. 5. There are extensive use of pipe fittings rather than hydraulic fittings.
Wish I lived near IC. We are up in Butler County. Maybe I will try to use a digital camera and get some pics of what I mean and put them somewhere online that I can let everyone see. We need to do work anyhow on the lines because they are leaking in places so we want to do it right. We got the tractor and loader from an elderly man that buys them and fixes them up. He has customized quite a few things on the tractor and the loader as it is (ie: loader frame has had a cutting torch applied on the inside of the horizonatal frame towards the front). He did a nice job on the 3 pt blade.
Thanks for the input and I will try to get a few pics. We have asked around and there may be a grumpy old guy that can come take a look (term used was nephews term LOL).
Allan In NE
12-09-2006 08:33:10
 Re: IH 2000 Loader-Need Advice in reply to KDJ in IA, 12-09-2006 07:10:59
Yep,
They've got a double acting cart hooked to a single acting horse.
Bet it is slow and probably doesn't have any capacity to speak of because it is continually fighting itself to even lift at all. :>)
Allan
KDJ in IA
12-09-2006 11:38:43
 Re: IH 2000 Loader-Need Advice in reply to Allan In NE, 12-09-2006 08:33:10
LOL Great analogy!
Yes very slow, have no idea the power as we just got it and haven't used it for anything but hopefully we can fix it before we do need the power.
old
12-09-2006 07:19:52
Sounds normal to me since a good number of loader where only power up and gravity down. I don't know that loader but the 2001 was gravity down with a trip bucket. Also a lot of time because of the size of the cylinders there just not enough fluid capacity on the tractor to have the loader go up all the way
Al L. in Wisc.
12-09-2006 06:09:21
Congrats on your purchase! The 2000 is a good loader and one in good shape is valuable. You will find great advise flowing your way, I"m sure regarding the "mechanics" of your plumbing. Pictures will help. As far as manuals, many recommend Binder Books. I have also seen them listed on ebay. Vintage manuals are what I seek, just something about the old stuff - tractors and all. Good luck w/your project. Enjoy
KDJ in IA
12-09-2006 08:22:27
 Re: IH 2000 Loader-Need Advice in reply to Al L. in Wisc., 12-09-2006 06:09:21
Thanks Al,
Could use your opinion for sure. If and when I run across any of those old manuals, I will let you know so you can add to your collection. LOL I have one for the 856 but I need it. Plus it is not that old yet, 74' I think.
I am working on the pics now but had to wait until the sun was overhead as the M was parked in the shadows of the corn crib.
IH2444
12-09-2006 06:05:04
I think manuals for the loader might still be available from binderbooks-dot-com.
BigMarv1085
12-09-2006 11:51:26
 Re: IH 2000 Loader-Need Advice in reply to IH2444, 12-09-2006 06:05:04
I have a 2001 loader on my 966 and it is pretty slow, plumb to the remote outlets. It had 1 cylinder in the center of the bucket and it was replace with 2 cylinders, 1 on each side of the loader frame and it is really slow.
