H specs?
H fanatic
12-09-2006 20:54:29
Hello,
What is the ring end gap supposed to be for a 46' Farmall H with stock pistons and sleeves (3 3/8 bore). Then what are the part numbers for the intake and exhaust valves also for a 46' Farmall H.
Thanks,
Nick
Nebraska Kirk
12-10-2006 14:53:33
 Re: H specs? in reply to H fanatic, 12-09-2006 20:54:29
Ring gap, .010" to .020"
My parts book shows 3 different valves, gas, distillate and kerosene.
Gas
50706DA intake
50707DA exaust
Distillate
57696D intake
57697D exaust
Kerosene
43912D intake
43913D exaust
Wayne Swenson
12-09-2006 21:25:18
New, minimum for any engine is .003" - .004" end gap per 1" of cylinder diameter. You need .011"-.014" minimum for your engine. That spec is for all piston rings.
