Help is it a Farmall AV?
Casefrank
12-10-2006 16:12:34
Can someone tell me just what I have aquired Serial # on engine block is FAAV M206401 G
It doesn't have the larger wheels Has a square tube adjustable front end and what is strange is a distributor with a hydrlic punp after the distributor Thanks
Frank
SuperA-Tx
12-11-2006 07:49:48
 Re: Help is it a Farmall AV? in reply to Casefrank, 12-10-2006 16:12:34
Maybe if you had a picture of it then someone would be able to tell you exactly what you had.
From what I understand the AV is about 8 inches taller that the SuperA, rest is the same. The diamond axle makes it an industrial. I think that was extra you had to order.
