Rear End Fluid
ScottF300
12-10-2006 17:10:18
What is the process of changing the rearend fluid in my 300? Where is the drain plug & fill hole?
What is the amount of HyTran I will need?
ScottF300
12-10-2006 17:11:24
 Re: Rear End Fluid in reply to ScottF300, 12-10-2006 17:10:18
I forgot to mention it is a Farmall 300 rowcrop.
Don LC
12-11-2006 07:35:22
 Re: Rear End Fluid in reply to ScottF300, 12-10-2006 17:11:24
Better check your manual, I think you need 90-140w gear oil..... .
Janicholson
12-10-2006 17:20:19
There are at least three pipe plugs on the underside of the tractore that need to be removed. The housings have several low spots (accounts for the plugs) but one fill in the platform. The various components will fill from there. Except the PTO which needs to be drained and filled seperately, though it does participate in the final drive lube when running. I do not know the quantity, however it is good to shop the fluid. Hytran is produced by outsourcing (in the USA so far) many fluids meet its specs. Cheap fluid from a box store is not good advice. JimN
