question about temp. of tractor.
Charles McNelly
12-10-2006 18:13:15
The arrow on the temp gauge(High side of run) is what, 160 degrees/180 degrees?????. This site carries a 160 degree thermostat but that seems kind of cool. What do you all think?
Thanks,
Charles
CNKS
12-11-2006 13:22:40
 Re: question about temp. of tractor. in reply to Charles McNelly III, 12-10-2006 18:13:15
If you mean an H (don't think other models would be much different), gauge working range for non-pressurized radiator is 130-160 degrees, pressurized 170-220. I would think either a 160 or 180 would work, in cold weather a 180 is probably better, as it takes those things forever to warm up. From practical experience with an H with a pressurized radiator, and a good cap, the cap releases water (not antifreeze, it seldom froze) as the gauge just creeps into the red. The 130-160 degrees makes little sense to me, since that's 52 degrees below the boiling point of water.
Cedric
12-11-2006 01:25:52
At one stage I thought my gauge wasn"t working properly so I immersed the bulb in a saucepan of water and slowly brought it to the boil. At the arrow the temperature was 200°. At the bottom end of the green it was 180°.
When burning distillate or kerosene the Owner"s Manual says to keep the pointer on the arrow by adjusting the radiator shutters. Sid.
IaGary
12-10-2006 18:25:28
All the gauges are a little different but when mine hits into the red a little it is boiling so it must be 212.
In the green past halfway would be over 180.
Gary
Charles McNelly III
12-11-2006 17:33:05
 Re: question about temp. of tractor. in reply to IaGary, 12-10-2006 18:25:28
Hi Gary, I called the dealer today and they said they were 195 degree for the M. They wanted close to $30.00 for it not including a gasket. I took the neck to the local Auto Zone and matched up a thermostat to fit the groove and bam I bought a 180 degree for $5.99. The needle goes a little over half way in the run. Still below the arrow but it's better then before, and alot cheaper to boot! Charles
