OT Trailer axle weight
mark k
12-10-2006 19:12:48
Hello,
I bought a trailer today and it only has one axle and I am wondering how to tell what the weight of the axle is? It is a 8 lug wheel and it is one that uses 90 weight gear lube insted of packing the bearing with grease. Any hints??
Thanks Mark
mark k
12-12-2006 19:47:18
 Re: OT Trailer axle weight in reply to mark k, 12-10-2006 19:12:48
It is one of the rubber torshion axles and it isn't a old truck rearend. I am thinking about buying another axle and putting it under it. It is a very well built trailer. Thanks Mark
Nat 2
12-11-2006 04:52:28
Does it have a "pumpkin?" In other words, is it an axle salvaged off the rear end of a pickup truck? If so, you're only looking at about 6000 pounds.
Even if it is a 10,000 axle, you may not want to put that much on a single-axle trailer if you plan on going anywhere at any speed. Single axle trailers are bouncy and unstable compared to tandems.
Don L C
12-11-2006 07:15:32
 Re: OT Trailer axle weight in reply to Nat 2, 12-11-2006 04:52:28
Sounds like a home made trailer with a truck floating axel with rear end gear..... hard to say what you got..... .sell it and start over----- ---Don
toolz
12-10-2006 20:30:45
I"ve never seen an axle with oil bath bearings less than 10,000 lb, but I could be wrong. My 7000lb 8-lug axles use grease, and my gooseneck has 10,000lb axles with oil bearings.
dan67
12-11-2006 08:37:48
 Re: OT Trailer axle weight in reply to toolz, 12-10-2006 20:30:45
I work in the Marine Field and in the last year they have come up with gear oil filled hubs down to 1000lb axle w/ 4:80x12 wheels. It is something fairly new
old
12-10-2006 19:27:37
Most of the time with 8 lugs its 7000lbs or more but there are some that aren't that high but have 8 lugs
