IA,A,AV and B wheels
Roger Mills
12-11-2006 08:18:58
I saw a post or two a while back about the two mount lug styles vs plain rims for these and have some info. IA,A, plus B,BN with double front-- standard front hubs were stepped not flat and the rims had no lugs, just clamps-not adjustable--A plus B,BN double front were also available with "special order" adjustable fronts with flat hub and rims with small 'U' shaped lugs. IA does not have adjustable front wheels or flat hubs listed. AV had flat hubs with larger diameter rims that had wide flat "V" shaped mount lugs. Rims with these 'V' shaped lugs for the A and B are after market. B and BN could be "special ordered" with both rear inners from heavy cast rather than steel. An oddity was that there are half weights (about 70 lbs) that could be ordered for the left rear on an A to balance the "Big Bubba" sized drivers. Very few of these were ordered and I cannot find a part number for them.
gene bender
12-11-2006 17:56:58
 Re: IA,A,AV and B wheels in reply to Roger Mills, 12-11-2006 08:18:58
AV is different as the rim sizes are larger that the rest of the series A,B,BN and C,SC and newer models. Two types clamp and the riveted bracket for adjustable tread spacing for mud or whatever type of spacing for the two front wheels Wts were avail and they weighed around 42lbs. The cast centers for rear around 145LBS with bolt on wts at around 145lbs. Dont know where you got the half wts thing all could be ordered with steel centers for rear or the heavy cast and of course wts front and rear. You can put an add-on wt on the inside of the steel center and another one or two on the outside. How much do you want? I have some of both fronts and rears name the set-up.
Roger Mills
12-12-2006 06:29:29
 Re: IA,A,AV and B wheels in reply to gene bender, 12-11-2006 17:56:58
My FAA has adjustable front axle with flat hubs and rims with the U shaped lug and had 3 weights per side. The rear has a thin weight on the left rear steel center and the cast right center with no weight. The IAA has an adjustable front axle with stepped hubs and no lugs on the rims and no front weights. The rear has two thick weights on each side with the same centers as the A. There is no casting number on the thin rear weight. I have both the A and IA parts books and the IA does not show the flat hubs or rims with lugs and neither book shows the thin weight. The local International/Komatsu dealer has one of the thin rear weights and said it came direct from International in '47 on a white IA, (weight is white)???. You are right, AV has taller rims and they are the ones that have the V shaped "tabs"? to bolt them on with. The post I saw had some confusion about these tabs on small diameter rims so I assumed they were after market.
