Farmall C w/ mounted planter
Farm W/Junk
12-11-2006 11:37:37
Hi I picked up a Farmall C with a 2 row mounted planter on it this weekend. Im a JD guy but a farmall H was my first tractor at 12 so I have a soft spot for them. Im familar with the H/M tractors but this is my first time around a C so I will have questions to come but I have a few basic ones now. I bought it not running but it has a new battery and turns over good but there is no coil on it so Im hoping that with a coil tune up and gas It will run. wish me luck. Anyways with the questions...How common are the planters? Do they work good? What drives the planter? Spun the planter wheels but it wouldnt run the plates, does the planter have to be down and the pressure from being on the ground let it engage? Or are there supposed to be a drive off the axle or something? What are the values of farmall c with a mounted planter? It is straight original still 6 volt good tin tires rims. Thanks for any help.
Matt
John in Ne.
12-11-2006 12:39:52
 Re: Farmall C w/ mounted planter in reply to Farm W/Junk, 12-11-2006 11:37:37
I had a C238 planter that was ground driven by two cast wheels on the front of the planter.John.
Randy in NE
12-11-2006 12:17:43
The packer wheel is what drives the planter. It is probably all rusted up throughout. I got a mounted planter for my Super C. I need to get two new tires for the packer wheels but otherwise mine turns over freely. The old grease was pretty stiff so had to work it a little to get it to operate. A little WD-40 did wonders for it. Mine came with the checker mechanism for rowing the corn from north-south and east-west. I am missing the check wire but the rest of the planter seems to be there. It had been "farmerized" over time so I need to get a few replacement parts. I do have the parts manual for all of the C implements if I can be of any help with the planter. My e-mail is uncovered.
