Fast Hitch Part Number
BOBM25
12-12-2006 04:42:04
I need a part or casting number for the left side mounting plate on a newer style fast hitch, the style with manual draft control. The part bolts directly to the tractor and has the hole for the pin that is inserted for the hitch to have down pressure. Mine is broken and I'm having trouble locating one without a part number. Thanks in advance, Bob
CNKS
12-12-2006 14:54:06
 Re: Fast Hitch Part Number in reply to BOBM25, 12-12-2006 04:42:04
Parts books are now online, www.caseih.com -- every number on the tractor is there.
D Slater
12-12-2006 06:56:19
For 450 or 560 type it will have the # 522695 R1,R2 or R3. I remember 2 types of swivel brackets that the hydraulic cylinder lower pin goes in. Think they will work complete on plates if switching but some of the swivel parts won't interchange from one to other type. Used to know what differances were but its to long ago for me to remember exactly. Remember a some plates with a lower number than what I posted also but could'nt find where I wrote # down. Did you ever figure out the hydraulics on SMTAD?
BOBM25
12-12-2006 07:34:41
 Re: Fast Hitch Part Number in reply to D Slater, 12-12-2006 06:56:19
The swivel part is separate from the piece I'm looking for, I think. I need the piece that the swivel part fastens to. The tab for the hole to lock the swivel part from swiveling is broke off. I figured the hydraulics out last night. I have a diesel pump and housing with a manifold block for a gasser under it. You were right, they are different pumps. They will not interchange. Now I just need to find a diesel manifold block, and pretty fast. I want her to get the into paint booth after Xmas. I got that entire week off work. Anybody know what happened to Geoff in NY, I need to get ahold of him?
D Slater
12-12-2006 07:41:25
 Re: Fast Hitch Part Number in reply to BOBM25, 12-12-2006 07:34:41
The # I posted is for the plate that bolts to side of trans. That # can be found on the plate,if you have your tractor plate off you should be able to find # on it. I just mentioned the other part in case you were switching some parts there also.
BOBM25
12-12-2006 08:38:01
 Re: Fast Hitch Part Number in reply to D Slater, 12-12-2006 07:41:25
Oh, sorry. I'll try that number. Looks like I need to take it apart to be sure though, huh? Guess that might be tonights project.
