super A wiring
banjo
12-12-2006 13:52:19
1948 super A, Magneto,Generator/cut out, 6volt pos ground, light switch, fuse.
I have lost my diagrahm i printed off for this tractor. I'm needing to hook the fuse,switch and genny up so i dont cook the battery.Could ya help me out PLEASE.
Keith-OR
12-12-2006 22:13:07
 Re: super A wiring in reply to banjo, 12-12-2006 13:52:19
banjo, here is a wiring diagram for your Super A.
This place has a owners manual on line, also parts cat. great site for lots of info for Farmalls.HTH
Keith & Shawn
banjo
12-12-2006 22:22:36
 Re: super A wiring in reply to Keith-OR, 12-12-2006 22:13:07
KEITH, your link doesn't show up. just plain ole type in the post.
Keith-OR
12-12-2006 22:17:00
 click reply for direct link in reply to Keith-OR, 12-12-2006 22:13:07
Once you are here click on the link for Super A wiring diagrams I posted on original reply..
Keith
banjo
12-12-2006 14:45:58
^Thanks , i thought that was the way it would work seeing how Bobs diagrahm showed a fuse on the switch that the fuse would hook to the ampmeter and the top upsidedown L peice.
Whoooh, i almost didn't get that all said with one breath.
I promise i will get an operators manual. I have the I&T shop manual and the internet. what more could you ask for.
CNKS
12-12-2006 14:50:58
 Re: super A wiring in reply to banjo, 12-12-2006 14:45:58
A parts book and IH service manual. Then you have printed copies, you can then ask questions about what you don't understand.
SuperA-Tx
12-12-2006 14:23:32
Heres the one out of the Operators Manual.
http://www.cleancomputes.com/Cub/Super%20A%20-%20Super%20AV/Super%20A%20-%20Super%20AV%20Owner's%20Manual/Page%2044.jpg
Yugrotcart
12-12-2006 13:54:49
Banjo,
Here's a link to "Bob M's" diagrams, take yur pick.
Paul
banjo
12-12-2006 14:08:46
 Re: super A wiring in reply to Yugrotcart, 12-12-2006 13:54:49
That is getting closer, but i still have 1 question. On the super a there is a fuse in the dash/panel. Where do i hook the 2 wires from it?
my switch is just a we bit different then the one pictured for the H/M. It shows a fuse on the back of the switch, where mine does not.
CNKS
12-12-2006 14:27:26
 Re: super A wiring in reply to banjo, 12-12-2006 14:08:46
One goes to the right + ammeter terminal, as viewed from the back -- this is the wire from the "side" terminal of the fuse holder, one goes to the top terminal of the upside down L shaped thing on the light switch, this wire appears to come from the bottom of the fuse holder, not going to tear mine up to look. You REALLY need an Operator's manual. The diagrams are very clear and straight forward.
