Bleeding air from Farmall 400 hydraulic system
Duanes
12-12-2006 14:57:44
The manual says to leave plug out of hydraulic reservoir and cycle cylinders through 10-12 times. Does this include loader as well? I would assume it does. Would you also not lose some hydraulic fluid?
Aberdale Farm
12-12-2006 17:48:50
 Re: Bleeding air from Farmall 400 hydraulic system in reply to Duanes, 12-12-2006 14:57:44
Yes, you will need to cycle the loader cylinders if the loader uses the same hydraulic system. I have had trouble bleeding air out of my 450 before. I ended up screwing a pipe nipple, elbow, and riser pipe into the fill hole. This allowed me to overfill the system slightly and create a little head pressure to force the air out. It also eliminates splashing by leaving the fill plug off. After the system is bled, I remove the pipe (which does make a bit of a mess) then reinstall the plug.
Dale
JayWalt
12-12-2006 17:28:46
On my 300u the lift rams would not bleed themselves by cycling. So What I had to do is this:
removed one of the rams, leaving the hose connected. Then use the tough control to extend the ram all the way out. Then while having the touch control in the down postion (these are one way cylinders), turn the cylinder so the hose is up in the air, then manually push the ram back in. The air will rise to the top where the hose is and when you push the ram in it will push the air through the hose and into the resevoir. I did this 2x on each cylinder, now no more bouncy loader. For the dump cylinders which are 2 way, I just cycled them like 5 times, as well as the hitch lift cylinder.
RustyFarmall
12-12-2006 15:12:47
Yes, that would be for the loader also. You might lose some fluid out of the fill hole if the plug is removed. How much would depend on how much air is in the system.
