H carb ?
banjo
12-13-2006 06:43:47
i have the carb off my 1941 H and the only numbers i can find appear to be cast numbers.6212-DB on the bottom and 6213-DA on the top half. I know it is IH carb as it is cast into it. What kit should i get?
Manuals are ordered at this time.
all the screws are stuck solid also. I twisted 2 of them off just getting the top off. I'm affraid the adjustment screws will twist off also. I don't know if soaking it will get down in far enough to loosen them.
MLD
12-13-2006 08:10:54
 Re: H carb ? in reply to banjo, 12-13-2006 06:43:47
One of my screws broke off too, I had enough left to get visegrips on to get it out. The brass idle jet broke right off very easy. I ran a small tap into the hole alittle at a time & backed it out. It slowly keep pulling the brass threads out a little at a time. The new one screwed right in. I was very scared to, but it worked out. Good Luck!
RustyFarmall
12-13-2006 06:57:02
Get the kit for the 50981 gasoline carb. Heat from a torch is your best friend when working on rusty carbs.
banjo
12-13-2006 07:00:18
 Re: H carb ? in reply to RustyFarmall, 12-13-2006 06:57:02
i'll try the heat, but im still nervous. I sure don't want to buy another carb. heck i only gave $200 for the whole tractor.
City-Boy McCoy
12-13-2006 14:37:35
 Re: H carb ? in reply to banjo, 12-13-2006 07:00:18
Sometimes the $200 tractor ain't the smart money investment.
mike
banjo
12-13-2006 14:55:59
 Re: H carb ? in reply to City-Boy McCoy, 12-13-2006 14:37:35
there is still $200 worth of parts . the question is, is it worth fixin?
old
12-13-2006 08:04:45
Now see theres another reason to make a road trip out this way. I have an H carb laying around in my shop. LOL. Good way if you can get away with it is to put the carb in your house oven and heat it up and then cool it down again. The heating and cooling helps brake things loose. But be sure to send the wife out for a couple hours and also have a couple cans of glade to help hide the smell from doing that
banjo
12-13-2006 08:18:09
 Re: H carb ? in reply to old, 12-13-2006 08:04:45
Aahaw, the wife just happens to be gone for a couple of days. she won't even know, i'll just let the dogs in the house to mask the odor.
banjo
12-13-2006 08:23:39
 Re: H carb ? in reply to banjo, 12-13-2006 08:18:09
Ya know , you keep it up and i'll be knocking on your door one of these days. I have an ole navy buddy up in Ill i might could con into dropping by if he ever decides to come visit.I wonder if he has a trailer.
RustyFarmall
12-13-2006 07:02:33
Another $200 invested in a good carb will result in a $400 tractor. Still dirt cheap.
banjo
12-13-2006 07:24:45
 Re: H carb ? in reply to RustyFarmall, 12-13-2006 07:02:33
yeah but it need a manifold also and front tire,water hoses,fuel line, starter switch, probably plugs,wires cap,rotor. before i know it it will be $1000 tractor.
glennster
12-13-2006 07:26:47
 Re: H carb ? in reply to banjo, 12-13-2006 07:24:45
ahhhh, but it will be one sweet tractor when its done!!!!! !!!!! !!!!! !!!!! !!!!
RustyFarmall
12-13-2006 07:34:59
 Re: H carb ? in reply to glennster, 12-13-2006 07:26:47
And $1,000 invested in a good running H is still very, very, reasonable. You could easily sell it for $1,500.
