sleeves or no sleeves
red man mark
12-13-2006 07:24:33
my ol' 460 finally started showing its age this summer so i decided time for a top end.once inside low and behold this engine is not sleeved.manual calls for sleeves,no over size pistons.all kits have sleeves included.bore is stock 3 9/16.did farmall make some sleeveless motors.local I/H dealer says no sleeves and over size pistons available.is this right?Help!year is a 1958 or59.
CNKS
12-13-2006 18:39:17
 Re: sleeves or no sleeves in reply to red man mark, 12-13-2006 07:24:33
I don't know the serial break but the C221 and C263 were sleeved early and sleeveless late, same bore and stroke in both, C301 was sleeveless the whole time. This is straight out of the engine service manual.
red man mark
12-13-2006 22:40:50
 Re: sleeves or no sleeves in reply to CNKS, 12-13-2006 18:39:17
this is interesting,didn't know both were offered.do you know if tractor and engine serial numbers should match?that could maybe give a year.thanks
CNKS
12-14-2006 07:46:48
 Re: sleeves or no sleeves in reply to red man mark, 12-13-2006 22:40:50
They don't match -- go to www.caseih.com, look for 460, and look at the engine parts.
ejr-IA.
12-13-2006 09:17:21
Does it have the 221 motor or did some one put a sleeveless 301 in the tractor?Theirs over bore pistons for the 301 and repair sleeves from clevite for the 221 for 39/16 bore,no. 226-8058.
red man mark
12-13-2006 22:32:23
 Re: sleeves or no sleeves in reply to ejr-IA., 12-13-2006 09:17:21
the engine is stamped c221 with serial#042915.the tractor itself is for sure a 1959.do you know if the c221 combine engines were sleevless.i here maybe they were.
El Toro
12-13-2006 08:29:43
Your local auto machine shop may be able to bore the block to accept sleeves. They probably have a source for sleeve and piston kits. There's probably an overbore kit available with thinner sleeves too. Hal
Allan In NE
12-13-2006 07:35:56
Yeah,
I ended up with one of those "doctored" tractors too. :>(
I imagine someone dropped in a combine motor somewhere along the way.
Allan
