Neuss D358 info needed urgently
locoman
12-13-2006 16:55:28
Would appreciate anyone giving me the following specs please as I have almost exhausted the web looking.
Weight inc. accessories. (wet or dry)
Length from flywheel to fan.
Height over all.
Hp and Torque.
A friend of mine needs the info as he is looking at repowering his small IH dual cab Truck. Any thoughts appreciated.
boerontour
12-17-2006 04:05:39
 Re: Neuss D358 info needed urgently in reply to locoman, 12-13-2006 16:55:28
what will you now, we get everything up here, these are the better engine"s over here in europe, other wise look at the site>Link
for>Link questions, mail me, cu.
locoman
12-13-2006 21:48:09
Thankyou gentlemen, I knew I could rely on this great forum, and I will post the outcomes for interest.
Cheers
billyiron
12-13-2006 20:48:37
I got a engine out of a school bus its a ih 359,,kinda hankering to put it a pickup,,I bet the engine would last forever,,,billy
Jim Allen
12-13-2006 19:29:42
Reading your e-mail closer, here is some more info. The IH tractors were rated for a max of 2400 rpm, but in trucks the limit is 3000 here is some updated info.
Hp- 135.6 @ 3000 (one source shows 140)
Torque- 266 @ 160
Piston Speed- 2530 FPS @ 3000 rpm
BMEP- 100 PSI
BSFC- .3699 #/hp hour @ 1800 rpm ( full-load, about 4.7gph)
Jim Allen
12-13-2006 19:14:46
Weight- 1160 lbs. (w/accessories)
Length- 40.74 inches
Height- 35.2 inches
Hp- 108 @ 2400 rpm (Neuss rated, variable in application)
Torque- 257 lbs-ft @ 1600 rpm (Neuss rated)
Engine Bolt Pattern- SAE-3
K.B.-826
12-13-2006 17:36:14
If you could give me until Monday, I could get the approximite measurements for you. If not, I know there are other guys on this board with 310's and 358's who would be happy to take some quick measurements. They will differ slightly depending on what appliction the engine came from, as there were different oil pans, spacers between fan and water pump, ect. As far as weight goes, should be about the same as any six-cylinder diesel in that cubic inch range, a rough guess would be 1200 pounds for the block, head, all internal parts, and the flywheel. I know that the 1420 combine with the 358 was rated at 120 horsepower at the flywheel. Tractors are rated at the PTO, and most tractors with that engine are around 90 PTO HP, which would probably work out to 100 at the flywheel. The pump can easily be turned up for more, and I bet it could do 150 and still be pretty reliable. Good luck with the project, I always thought a 358 would make a neat engine for a truck, as they like to rev high and are very easy on fuel.
