removing hoods
Randy as in Ran
12-13-2006 19:19:26
Hi , A real simple question . What's the easiest way to remove the hood by your self ? This happens to be a M farmall . If I lift on one side the other side hangs up , so over to the other side , same thing . It's a good thing my tractor is nothing but rust because if it had a nice paint job I'd be ripping what little hair out that I still have . Any tricks to it ? Thanks ...Randy
Bob M
12-14-2006 06:19:19
 Re: removing hoods in reply to Randy as in Randy-IA, 12-13-2006 19:19:26
Obviously the best way is to have one person on each side! However when a helper is not available I use a couple wood blocks (2x4 scraps or similar) and a step stool or inverted 5 gal bucket
First undo all (4) hood latches. Then disengage and lift the rear of the hood far enough to slip a wood block between the top of the gas tank and the hood. Now go to the front of the tractor and do the same, inserting the 2nd block block between the top of the radiator and the hood. Finally place the step stool on the left side the tractor about in line with the exhaust stack, then stand on it, reach across and grab the hood and lift it free.
Simply reverse the above steps to replace the hood.
little john
12-14-2006 03:56:31
I put a small pulley overhead and ran a cord down to a wood rod which ran under the hood. I could pull the hood straight up and let it hang there while working on the engine.
the tractor vet
12-13-2006 20:02:11
A five gallon bucket works well, Oh yea make sure the big end is down .
CNKS
12-13-2006 19:27:23
Small stepladder, unless you are 6'6", grab in middle and lift straight up, turn the hooks sideways first.
banjo
12-13-2006 19:26:36
might try getting a ladder so you can reach across and get ahold of both sides so they dont flop back down. or get a couple of rods to slide under it to hold it up. be careful and don't mess up the patena.
Mike CA
12-13-2006 23:00:32
 Re: removing hoods in reply to banjo, 12-13-2006 19:26:36
patena?
Did you mean "paint"?
banjo
12-14-2006 00:07:43
 Re: removing hoods in reply to Mike CA, 12-13-2006 23:00:32
no i meant that antique pa teen a(sp)
City-Boy McCoy
12-14-2006 05:29:43
 Re: removing hoods in reply to banjo, 12-14-2006 00:07:43
I like a tractor with patina finish and straight sheet metal. They look very original and yet cared for. (Guess this does not answer your hood question.)
mike
Jim in NC
12-14-2006 03:31:43
It may be patina. I have a photographer friend that is into it big time.
