SLAPPY
banjo
12-14-2006 10:53:48
I just went and looked for a oem kit but i did not see one listed.
RustyFarmall
12-14-2006 11:37:01
 Re: SLAPPY in reply to banjo, 12-14-2006 10:53:48
The 50981 is the kit you want, and it is not for a Zenith. I have never seen a Zenith carb on an H. Don't think there is such a thing. Before ordering though, you might want to contact YT and tell them to double check their listings.
RustyFarmall
12-14-2006 11:39:37
 Re: SLAPPY in reply to RustyFarmall, 12-14-2006 11:37:01
I might add that you want the comprehensive kit, hopefully it will have all of the parts in it that are supposed to be there.
banjo
12-14-2006 11:05:19
 Re: SLAPPY ? others also in reply to banjo, 12-14-2006 10:53:48
these are the kits listed on this site. which one is correct? it is IH dual fuel Carb
Yep i'm still messin with the carb on this H. Need to get it back together and leave it alone before i break something.there is no brass tag to identify it just cast numbers. It was suggested earlier to get the one for the 50981-DA, but it does not have Zenith anywhere on it just IH cast in it.
----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- -- 1 Carburetor Kit, Basic - For H, HV and 4 (Distl.) with OEM# 45108DB and 50981DA. Contains the following parts for a Major Overhaul with instructions. Includes: gaskets, needles, seats, shafts and springs. (Part No: BK10V) $18.20 [Enlarge Picture]
----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- -- 2 Carburetor Kit, Basic - Kit for IHC 45108DD, 50981DC carbs on H. (Part No: IH102) $18.00 [Enlarge Picture]
----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- -- 3 Carburetor Kit, Comprehensive - For H, HV and 4 (Distl.) with OEM# 45108DB. Contains the following parts for a Major Overhaul with instructions. Includes: gaskets, needles, seats, shafts, springs, and mixture screw. Does not include float. (Part No: C510V_) $28.66 [Enlarge Picture]
----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- -- 4 Carburetor Kit, Comprehensive - For H, HV and 4 with Zenith 50981DA. Contains the following parts for a Major Overhaul with instructions. Includes: gaskets, needles, seats, shafts, springs, and mixture screw. Does not include float. (Part No: C510HV) $29.30 [Enlarge Picture]
