Update on Binder manual for Genius plow
CenTex Farmall
12-15-2006 11:37:33
Ordered the later manual from Binder Books for the #8 plow. As Hugh MacKay said, it has update information in it, most namely the hydraulic and rubber tire additions, and covers earlier plows. Goes in to all the detail you would expect from a factory manual. Hopefully this helps anyone with the same question I had.
teddy52food
12-15-2006 14:53:47
 Re: Update on Binder manual for Genius plow in reply to CenTex Farmall, 12-15-2006 11:37:33
If they are the old style shear, ( not throw aways ) I have a limited supply of points and edges.
CenTex Farmall
12-15-2006 19:52:11
 Re: Update on Binder manual for Genius plow in reply to teddy52food, 12-15-2006 14:53:47
I'm not sure if these are old style or what, but the edges/points have been replaced by ones that are welded on. I haven't put it in the ground yet, still doing some refurbishing, but they look to be in decent shape, all things considered. One of them has some pitting where it was resting in the dirt. It could stand to be replaced. I would be interested in parts if they'll work.
LJS01
12-15-2006 14:18:47
Can you still get earth contact parts for these plows? If so, Where?
