895 Case-- IH
Matthew Neely
12-15-2006 14:52:26
Looking to buy this 895 4x4 tractor.Fellow says as is.Checked over and seems a good deal,except the 4x4 will not engage when you flip the switch.I know this could be major, but could it be something simple like a fuse or ???.Any other matters with this model I should be aware of? Tractor has full cab,91 year model,3000 hrs.Thanks for any advise. Matthew.
Diesel Bob
12-16-2006 07:11:51
 Re: 895 Case-- IH in reply to Matthew Neely, 12-15-2006 14:52:26
the 4wd system should always fail into 4wd if hyd pressure or electrical power fail it should go into 4wd you can experience no 4wd if the coulping or splines on the 4wd shaft fail this can be expensive if the front axle drive shaft splines are worn badly
