Super A brakes
jerry vanderhei
12-16-2006 08:41:03
I am trtying to replace the brakes on my super A. I have the anual but it does not tell me much. I am working on the right side. I have removed the Tire, rim and hub.I have removed the 8 bolts holding the Final drive assembly to the brake band housing below the right fender, Is there anything else I must do to remove the final drive and accee the brake?Thank you foryour help.
Jim Becker
12-16-2006 16:34:43
 Re: Super A brakes in reply to jerry vanderheite, 12-16-2006 08:41:03
Don't forget to unbolt the drawbar.
kevinez
12-16-2006 09:52:05
I'm going on that you are removing drop housing that has the extension tube on it (just below the seat).
When I removed mine it was during a total disassembly of the tractor for restoration (still ongoing). I found that the extension tube and the drop housing were pretty much stuck together after being together for 50+ years. It took me some time with judicious tapping evenly all around. Be careful as these are cast pieces and banging away at them can break them. Also, the pin that holds the brake end together may have rusted tight and is causing you your difficulties.
On another note, you may not be doing this, I had some difficulties removing the brake drum as it machining tolerance was tighter than spec'd. Had to make a special puller to remove it. You'll need to remove it if you are going to replace any failed seals.
Good luck.
