Frost right above the Carb.
Tom Lee
12-16-2006 21:22:02
Got a 400 international and right above the carb. it wants to frost up....anybody know why it does this and what to do to remidy the situation...Tom
old
12-17-2006 08:26:52
 Re: Frost right above the Carb. in reply to Tom Lee, 12-16-2006 21:22:02
Believe it or not it does that all year round but you don't notice it as much in the summer becasue the manifold warms up faster. All you need to do is let it warm up a bit if it causes any problems with the way it runs
Bob
12-16-2006 21:25:56
The frost is caused by the air/gasoline lixture expanding and cooling after passing through the carburetor's venturi.
The actual visible frost shows up the worst in cold, damp weather.
It is NORMAL, nothing NEEDS to be done about it.
Tom Lee
12-17-2006 08:03:07
 Re: Frost right above the Carb. in reply to Bob, 12-16-2006 21:25:56
Thanks guys...just checking on it....Tom
Allan In NE
12-17-2006 03:51:55
Here Again,
I cannot understand why this bothers folks. It is as normal as rain and is a totally common occurance.
Allan
gene bender
12-17-2006 04:21:37
 Re: Frost right above the Carb. in reply to Allan In NE, 12-17-2006 03:51:55
Yes ALLAN their carbs on their cars done the same thing but they couldnt see under the hood nor were they around a tractor before.
