Farmall H Brake lock option.
Andrew Z
12-17-2006 08:54:22
I got a M&W brake lock opotion for our Super H, and I was wondering how does this go on and supposed to work are there any pics of how this is supposed to go??
Thanks for the Help
Andrew
Randy as in Randy-IA
12-17-2006 10:23:46
 Re: Farmall H Brake lock option. in reply to Andrew Z , 12-17-2006 08:54:22
Are you talking about one of those ebay replicas ? Or more accurately one that the replicas copy ? The bar that you flip the lock up with using your left foot ? If so it just bolts to the platform in front of the steering post using two platform bolts with spacers under them I think . I've never used one but they look easy enough to install if that's the one you are talking about . If not Sorry , can't help . ...Randy
PS - I've seen a couple of different types and the easieast one to use that I've seen is the one the guy used a lawnmower choke cable , ran it under the torquetube to the front of the ratchet pawl and attached it to a small hole there on the inside edge . Just pulled the choke cable with his left hand while the brakes were applied . It left his left foot and right hand free to do what they are supposed to be doing ( clutch and governor ) . The second benefit was the ratchet couldn't be accidentally engaged because the cable was pushing it up . Never heard of that happening but I suppose it could . Some fabrication of brackets was required to hold the cable to the front brake cover bolt and the top to the steering post . This was on a M .
Andrew Z
12-17-2006 12:18:12
 Re: Farmall H Brake lock option. in reply to Randy as in Randy-IA, 12-17-2006 10:23:46
Yes that is the one. the one that has a rod that goes up the tree. Im assuming this does not interfere with the hydro control leverls?
thanks
Andrew
Easy1
12-17-2006 15:13:21
 Re: Farmall H Brake lock option. in reply to Andrew Z , 12-17-2006 12:18:12
I just bought one from O.E.M. tractor parts. It has a rod with a loop at the top that peeks out above the lightbar. It has a samll bracket that mounts on the ammeter box. Works real nice, and I don't have to lean down to set the brake. I am trying to find different options for my H, just to have something different, and maybe add a little utility.
