C hyd. Manifold
SDE
12-18-2006 15:37:43
The large line is a return/supply line. The smaller one is the pressure. There is a slot milled into the face of the manifold that connects to the return line. Is this a pressure relieve bypass for the touch control system?
Harold Hubbard
12-20-2006 03:29:00
 Re: C hyd. Manifold in reply to SDE, 12-18-2006 15:37:43
If you look at the mating surface of the touch control block you will see a small hole that lines up with the end of the slot in the manifold. I think this leads to the pressure relief valve.
