WD-9 Duals
mib61
12-18-2006 18:17:11
I am wondering if the WD-9 rear end will stand up with duals on...I have new 18-4-34 151 Firestones on it and i would like to dual it with the same. I do not run fluid. I do use the tractor, but more to play with than anything. It would be more for looks than anything.
Hmmmmm, I think i just answered my own question.
mib61
12-19-2006 19:31:34
 Re: WD-9 Duals in reply to mib61, 12-18-2006 18:17:11
Ummmmm m.... I forgot to mention, My WD-9 dyno's at 84 hp @ 1800 rpm.....my bad!
Roger in Iowa
12-19-2006 19:23:47
Didn't ever know that '9s had troubles with rear ends. Lots of early pullers use them due to the ease of bolting up about any engine/clutch and straight thru in 5th gear.
560's were another story!
Roger in Iowa WR9 owner
iowa_tire_guy
12-18-2006 19:48:11
The rear ends on the W9s were not over built, at least that is the word from a relative who wrenched in an IH dealership in the 50's. I would think that for no more hard work than you do with it you wouldn't have a problem as long as you aren't kicking op the hp or adding weight. I just happen to have a set of rim clamp duals for 18.4-34 if you would need them.
glennster
12-19-2006 10:02:57
 Re: WD-9 Duals in reply to iowa_tire_guy, 12-18-2006 19:48:11
i be interested in the set, do you have the spacers and clamps? let me know how much you want for them, e mail me. also looking for a set of spacer rings for clamp on duals for farmall m. i have the duals, however the spacers seemed to have sprouted legs and walked off. thex glenn
glennster
12-18-2006 18:56:19
we had duals on our w-9, the inners were loaded. tractor pulled good. when we got the 706, we put the duals on that tractor. unfortunately, we sold the 706, kept the w-9, now i wish i had duals for my w-9....maybe i'll find a set at a sale
