hydro fluid leaking out of my 51 h
city farmer
12-20-2006 14:29:38
have a 51 h that i just use to take to shows and ride the kids on and pull hay trailer noticed that hydro fluid is leaking when it is shut off and parked leaking out not quite center of tractor how difacult is this to fix and is this hurting anything as long as i keep trans and rearend full leaked out about a half a cup ful this weekend this apears to be a problem where you have to split the tractor in half to replace a seal i do not have any exp. in doing this should i takele this job myself i have the tools and shop but need your help and advice would not do this prob till spring thanks MARK
city farmer
12-20-2006 17:11:56
 Re: hydro fluid leaking out of my 51 h in reply to city farmer, 12-20-2006 14:29:38
AFTER GOING AND HAVING A BETTER LOOK I THINK THE PROBLEM IS OIL LEAKING OUT OF THE TRANSMISSION REAR END THE OIL IS THICK AND BLACK MARK
Janicholson
12-20-2006 17:34:08
 Re: hydro fluid leaking out of my 51 h in reply to city farmer, 12-20-2006 17:11:56
If it is comming out of the cover behind the pump, but in front of where the hitch swinging drawbar attaches, it is probably trans 90 wt oil (especially if it smells sulfery) that seal is also in the same location and the pump needs to be pulled to service it. A stiff square 1/2"X1/2" bar will turn the coupling nut off (many posts on the countershaft seal on Hs and Ms). No big deal, keep the fluid up in the interum (plug on left in front of left brake on side of trans) should be within one finger joint of the bottom of the plug hole. JimN
Janicholson
12-20-2006 15:21:28
Mark, that is not an issue that requires splitting. (if it is indeed Hydro oil) The pump comes out of the bottom by removing all the pipe fittings and control lever. Turning the drive coupling to it from the trans countershaft so it is vertical, then lowering the pump on a floor jack. It is cool to operate the tractor without the pump, just cover the hole with a 16ga sheet metal plate. The pump seals are available, and not hard to repair. Keep us in formed. JimN
Charlie M
12-20-2006 15:18:18
If its leaking in the middle of your tractor it could be ether the seal or gasket on the belly pump or there are 2 shafts going into the transmission that have a seal. The belly pump has its own hydraulic oil so if its a light oil its probably the pump. You can remove the dust cover between the pump and transmission and have a look without removing the pump, You can drop the pump out rather easily (does take 2 people because of the weight), intall a seal and put it back. It might help to disconect the drive shaft to the pump as a temporary fix. You should be able to get the seal at a dealer or take the numbers off of it to a NAPA store.
