Questions about a 560
Lincoln
12-20-2006 16:57:17
Are the 560 gas tractors notorious for burning a lot of fuel? Are they as bad as a JD 3020 gasser.
Do all 560s have live PTO or was this option?
If the TA slips on the low side, can it still be used on the other side without problems? I am planning on running a small square baler with it, not doing much heavy work so I am thinking the TA won't be a problem.
Matt in ND
12-20-2006 18:44:46
 Re: Questions about a 560 in reply to Lincoln, 12-20-2006 16:57:17
I think the 560 is a lot easier on fuel then a JD. We had a 3010 on a square baler, and you couldn't get a full day on a tank, maybe 8-10 hours. THe neighbors baled with a 560, and it seemed like they would go a lot longer then we could.
K.B.-826
12-20-2006 17:20:29
It will probably be a tiny bit harder on gas than the 3020, but not by much. The PTO unit was an option, but if it has a PTO, it will be live. Never seen a 560 without a PTO. Yes, you can run on the high side of the TA for as long as you want without causing any further problems.
