TA Clearance
Big Country
12-20-2006 18:49:43
How much is to much clearance on the overrunning clutch and the ramp? Can you get over size roller for clearance? Any help would be helpful.
Nat 2
12-21-2006 13:15:04
 Re: TA Clearance in reply to Big Country, 12-20-2006 18:49:43
Again, why do you insist on spending $800 rebuilding part of this T/A when you can get an entire rebuilt unit for a little bit more than half that cost?
Wardner
12-20-2006 23:03:07
Yes, oversized rollers are available but I think they are used with a re-ground ramp. I have never re-built a TA so I am on shaky ground here. I believe that Hi-Capacity will sell you both along with incidentals such as seals and gaskets.
If I were to re-build a TA, my first purchase would be a manual describing the process.
