farmall m lift all question
Mike Schwartz
12-20-2006 23:04:22
Hello, The farmall M that I am working on has a Horn loader that has two stage hyd cylinders on it. The fluid capacity of the original pump is not enough to fully raise the loader. Can I add an additional resevoir above the pump to increase the volume of oil without causing problems? Also, can I use the factory two way valve off of my SMTA with live Hyd on the '51 M with belly pump? Thanks, MikeS.
Mike Schwartz
12-22-2006 01:24:09
 Re: farmall m lift all question in reply to Mike Schwartz, 12-20-2006 23:04:22
Jakee, do the cylinders on your '43 H mount under the front of the engine and run back towards the steering wheel at about a 45 degree angle? If I raise the loader some and add more oil it will go all the way up but when I lower it back down it pukes the extra oil back out. P.O. had a extra tank cobbled on but everything leaked so trying to clean up some. Would like to see a pic of your loader if you have one? Jed, thanks for the info, Mike S.
jakee
12-21-2006 14:15:38
have a 43 H with horn loader and belly pump and two stage cylinders and it will put the loader strait up over the tractor, are you putting enough fluid in i dont run a secondaier holding tank.
dej(JED)
12-21-2006 05:23:38
Mike-You can do both. Add a reservoir and use the double acting valve.
