606 with 560 crank?
Chrisco
12-21-2006 14:08:34
Can you or have you ever put a 560d crank shaft into a 606d? I was thinking of adding horsepower to a 606d just by stroking it. or are there other problems with this switch out?
560d 606d 282 236
3.6875 X 4.3906 3.6875 X 3.6875
migraine
12-21-2006 20:36:51
 Re: 606 with 560 crank? in reply to Chrisco, 12-21-2006 14:08:34
That is what I did when I built my 460 pulling tractor. Found a standard 282 crank and had it checked out and put in the 236. I then balanced the motor which cost 200 bucks and put in victor head gasket on the port and polished head, added a turbo and turn it at 3200 Rpms. The crank from gas 263 will also fit right in the 221 gas 460 motor and make that 460 come to life. Crankshafts from 282 diesel motors are pretty easy to find around here. If you need help shoot me an e-mail. Kinda wonder how a 606 with short wheelbase would do for pulling? migraine
Chrisco
12-22-2006 03:39:41
 Re: 606 with 560 crank? in reply to migraine, 12-21-2006 20:36:51
I am just looking at a 606 with a bad crank. I am not into pulling but I do have the crank some were here.
